Salta al contenuto principale
Canon PIXMA MP620B Scanner Light Replacement
Cosa ti serve
    1. Canon PIXMA MP620B Scanner Light Replacement, Separate the scanner cover from the rest of the lid assembly: passo 1, immagine 1 di 1
      • You will have to pry off the glass cover lid. There are no screws that you have to worry about. Just insert a spudger into the crack between the glass lid and black base as shown.
      Chiedi a FixBot
      Aggiungi Commento
    2. Canon PIXMA MP620B Scanner Light Replacement, Lift the glass cover of the scanner and take out scanner light: passo 2, immagine 1 di 1
      • After lifting the glass cover up, the light assembly will come free because it was only held in place by the glass top.
      Chiedi a FixBot
      Aggiungi Commento
    3. Canon PIXMA MP620B Scanner Light Replacement, Unplug the white wire from the scanner light assembly: passo 3, immagine 1 di 1
      • Now that the scanner light assembly is free. Lift it out of the scanner bed and unplug the large white wire that attaches it to the rest of the printer.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 6-21, Maness Fall 2014 Membro di Cal Poly, Team 6-21, Maness Fall 2014
CPSU-MANESS-F14S6G21
4 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 32
Tutti i Tempi: 3,015
