Salta al contenuto principale
Canon EOS 40D Shutter Button Replacement
Cosa ti serve
    1. Canon EOS 40D Shutter Button Replacement, Battery: passo 1, immagine 1 di 1
      • Locate the battery compartment cover on the bottom of the camera below the shutter button.
      Chiedi a FixBot
      Aggiungi Commento
    2. Canon EOS 40D Shutter Button Replacement: passo 2, immagine 1 di 1
      • Find the marked arrow on the battery compartment cover labeled "BATT. OPEN". Slide the lever following the arrow's direction and lift at the same time to release the latch.
      Chiedi a FixBot
      Aggiungi Commento
    3. Canon EOS 40D Shutter Button Replacement: passo 3, immagine 1 di 1
      • Release the lever and allow the battery compartment cover to completely open.
      • Remove the battery.
      Chiedi a FixBot
      Aggiungi Commento
    1. Canon EOS 40D Shutter Button Replacement, Shutter Button: passo 4, immagine 1 di 1
      • Peel off the grip material from the body of the camera, exposing the screws.
      Chiedi a FixBot
      Aggiungi Commento
    2. Canon EOS 40D Shutter Button Replacement: passo 5, immagine 1 di 1
      • Remove the rubber eyepiece by sliding it upwards.
      Chiedi a FixBot
      Aggiungi Commento
    3. Canon EOS 40D Shutter Button Replacement: passo 6, immagine 1 di 2 Canon EOS 40D Shutter Button Replacement: passo 6, immagine 2 di 2
      • Remove the three 5.0 mm Phillips #000 screws.
      • Remove the single 12.0 mm Phillips #000 screw.
      Chiedi a FixBot
      Aggiungi Commento
    4. Canon EOS 40D Shutter Button Replacement: passo 7, immagine 1 di 1
      • Remove the two 3.0 mm Phillips #000 screws on the bottom of the camera.
      Chiedi a FixBot
      Aggiungi Commento
    5. Canon EOS 40D Shutter Button Replacement: passo 8, immagine 1 di 2 Canon EOS 40D Shutter Button Replacement: passo 8, immagine 2 di 2
      • Remove the side cover using a plastic opening tool or your hands.
      • Use a plastic opening tool to gently start prying the rear case up from the rest of the camera.
      Chiedi a FixBot
      Aggiungi Commento
    6. Canon EOS 40D Shutter Button Replacement: passo 9, immagine 1 di 2 Canon EOS 40D Shutter Button Replacement: passo 9, immagine 2 di 2
      • Use the tip of a spudger to disconnect the ZIF connector on the left side of the camera.
      • The ribbon cable on this device was torn in the process of removing the back case, so there are no photos showing this step.
      • Disconnect the ribbon cable securing the rear case to the motherboard.
      • Separate the rear case from the camera.
      Chiedi a FixBot
      Aggiungi Commento
    7. Canon EOS 40D Shutter Button Replacement: passo 10, immagine 1 di 3 Canon EOS 40D Shutter Button Replacement: passo 10, immagine 2 di 3 Canon EOS 40D Shutter Button Replacement: passo 10, immagine 3 di 3
      • Remove the five 3.0 mm Phillips #000 screws.
      • Remove the two 5.0 mm Phillips #000 screws.
      • Remove the single 3.0 mm Phillips #000 screw.
      Chiedi a FixBot
      Aggiungi Commento
    8. Canon EOS 40D Shutter Button Replacement: passo 11, immagine 1 di 1
      • Pull off the cover.
      Chiedi a FixBot
      Aggiungi Commento
    9. Canon EOS 40D Shutter Button Replacement: passo 12, immagine 1 di 1
      • Use a plastic opening tool to flip up the black retaining flap on the ZIF connector.
      • Pull the ribbon cables free of the connectors.
      Chiedi a FixBot
      Aggiungi Commento
    10. Canon EOS 40D Shutter Button Replacement: passo 13, immagine 1 di 2 Canon EOS 40D Shutter Button Replacement: passo 13, immagine 2 di 2
      • Remove the side panel by unscrewing three 5 mm JIS #000 screws.
      Chiedi a FixBot
      Aggiungi Commento
    11. Canon EOS 40D Shutter Button Replacement: passo 14, immagine 1 di 2 Canon EOS 40D Shutter Button Replacement: passo 14, immagine 2 di 2
      • Remove the two 5 mm screws from under the wheel and under the shutter button using a JIS #000 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    12. Canon EOS 40D Shutter Button Replacement: passo 15, immagine 1 di 3 Canon EOS 40D Shutter Button Replacement: passo 15, immagine 2 di 3 Canon EOS 40D Shutter Button Replacement: passo 15, immagine 3 di 3
      • Remove the red and yellow plugs from their sockets using the plastic opening tool.
      • Position the tip of the tool under the raised plastic line, then push up.
      Chiedi a FixBot
      Aggiungi Commento
    13. Canon EOS 40D Shutter Button Replacement: passo 16, immagine 1 di 3 Canon EOS 40D Shutter Button Replacement: passo 16, immagine 2 di 3 Canon EOS 40D Shutter Button Replacement: passo 16, immagine 3 di 3
      Strumento utilizzato in questo passaggio:
      • Remove the cable running from the top of the camera to the black and white box.
      • Use a pair of precision tweezers to poke through the rubber coating and create a path for the wire to slide out.
      • Disconnect the wire by sliding it away from the rubber.
      Chiedi a FixBot
      Aggiungi Commento
    14. Canon EOS 40D Shutter Button Replacement: passo 17, immagine 1 di 1
      • Use a Phillips #000 screwdriver to remove the two 5.0 mm screws and single 7.0 mm screw.
      • Notice that one is screwed in from the side.
      Chiedi a FixBot
      Aggiungi Commento
    15. Canon EOS 40D Shutter Button Replacement: passo 18, immagine 1 di 3 Canon EOS 40D Shutter Button Replacement: passo 18, immagine 2 di 3 Canon EOS 40D Shutter Button Replacement: passo 18, immagine 3 di 3
      • Once the screws are removed, wiggle the piece out of its socket and flip it over, exposing the shutter button.
      • Use tweezers to separate the piece from the ribbon that it is glued to.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 12-3, Blackwell Fall 2015 Membro di USF Tampa, Team 12-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G3
4 Membri
16 guide realizzate
3Commenti sulla guida
Thanks for these instructions. I've successfully replaced the shutter button assembly on my Canon 50d using this guide.
William Eggers - Rispondi Condividi
Thank you for the tutorial. I don’t know how to replace the button. Which glue to use ? Must it scratch the connections on the flex circuit before gluing the new button ?
Tony - Rispondi Condividi
Thanks for this, but this is missing a lot of steps, and you didn't mention the jis #000 in the tools...
New Town - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 16
Ultimi 30 giorni: 81
Tutti i Tempi: 11,074
