Salta al contenuto principale
CM Storm QuickFire Rapid LED Light Replacement
Cosa ti serve
  1. CM Storm QuickFire Rapid LED Light Replacement, Removing Keycap: passo 1, immagine 1 di 2 CM Storm QuickFire Rapid LED Light Replacement, Removing Keycap: passo 1, immagine 2 di 2
    • Insert the keycap puller around the key with the defective LED and pull upward.
    Chiedi a FixBot
    Aggiungi Commento
  2. CM Storm QuickFire Rapid LED Light Replacement: passo 2, immagine 1 di 2 CM Storm QuickFire Rapid LED Light Replacement: passo 2, immagine 2 di 2
    • Using a Philips #0 screwdriver, remove the .5cm screw from the back of the keyboard.
    • This will void your warranty!
    • When inserting the screw after fixing the faulty LED, make sure to not screw in too tight. This may cause erratic behavior with the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
  3. CM Storm QuickFire Rapid LED Light Replacement: passo 3, immagine 1 di 3 CM Storm QuickFire Rapid LED Light Replacement: passo 3, immagine 2 di 3 CM Storm QuickFire Rapid LED Light Replacement: passo 3, immagine 3 di 3
    • Wedge a plastic opening tool between the rear plate and rim of the keyboard and slide it through the circled areas to separate the plastic hooks that mount the rim to the rear plate.
    Chiedi a FixBot
    Aggiungi Commento
  4. CM Storm QuickFire Rapid LED Light Replacement: passo 4, immagine 1 di 2 CM Storm QuickFire Rapid LED Light Replacement: passo 4, immagine 2 di 2
    • Firmly grasp the bottom panel of the keyboard and carefully detach it from the rest of the board.
    • Do not put strain on the ribbon cable when lifting the bottom panel.
    Chiedi a FixBot
    Aggiungi Commento
  5. CM Storm QuickFire Rapid LED Light Replacement: passo 5, immagine 1 di 2 CM Storm QuickFire Rapid LED Light Replacement: passo 5, immagine 2 di 2
    • Detach the 4-pin cable from the bottom panel of the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
  6. CM Storm QuickFire Rapid LED Light Replacement: passo 6, immagine 1 di 1
    • Desolder the joints holding the faulty LED and switch to the PCB.
    • Slide the faulty LED out and replace it with the functional one.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Andrew
Membro da: 10/12/14
321 Reputazione
2 guide realizzate
Cal Poly, Team 6-23, Maness Fall 2014 Membro di Cal Poly, Team 6-23, Maness Fall 2014
CPSU-MANESS-F14S6G23
4 Membri
12 guide realizzate
4Commenti sulla guida
What kind of leds is it? Where can I get them?
Joakim Slettemeaas - Rispondi Condividi
3 mm white leds. I don’t know what voltage or effect they should be at though. I’m guessing 10-20 mA at around 2V, but mind you I’m just guessing… :(
Starfighter Johansson - Rispondi Condividi
So I'm having an issue with the LED backlight -- not a single LED, I mean the entire backlight. The FN key and the windows lock key (f12) light up when they are supposed to, but the function keys that are supposed to toggle on and off the rest of the backlight no longer do so (f1-f4 keys). Yet the f1-f4 keys clearly work, for instance, pressing f1 brings up the Chrome help menu, as intended. Any idea whether this is fixable, or how? I assume there is some circuit that controls the toggling on/off of the backlight for most of the keys, so maybe an issue with that?
Thanks for any suggestions.
Sam S. - Rispondi Condividi
Seems this is a common problem with these %#*@ keyboards. About one third of my keys are no longer backlit. POS.
gslinger - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 31
Tutti i Tempi: 9,407
