Introduzione
This guide provides step-by-step instructions to replace the dials on the Boss CE-300 Super Chorus, a vintage analog effects processor known for its rich chorus sounds. The dials, which control parameters like chorus level and tone, may wear out over time, resulting in inconsistent adjustments or complete failure. Replacing them restores functionality and ensures precise control.
The process involves disassembling the device, removing the faceplate, and carefully de-soldering the old dials from the circuit board before soldering new ones in place. Essential tools include a Phillips #2 screwdriver, 11mm and 14mm wrenches, a soldering iron, and a desoldering pump or braid for safe removal of solder joints.
This task requires basic soldering skills and attention to detail to avoid damage to the circuit board. Follow each step carefully, and ensure the device is powered off and unplugged before beginning to ensure safety and success.
Cosa ti serve
Use a Phillips #2 screwdriver to remove the 3 14.8 mm screws located on the left side of the CE-300.
Repeat the previous bullet on the right side.
Remove the following screws with a Phillips #2 screwdriver:
Two 7.5 mm
Two 10 mm
Remove the single 5.7 mm screw on the left side of the face plate.
Repeat the previous step on the right side of the face plate.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
