Salta al contenuto principale
Beats Studio 2 Wireless Battery Replacement
Cosa ti serve
    1. Beats Studio 2 Wireless Battery Replacement, Battery: passo 1, immagine 1 di 2 Beats Studio 2 Wireless Battery Replacement, Battery: passo 1, immagine 2 di 2
      • Using a spudger, remove the panel circling the ‘b’ Beats logo on the right earphone by applying pressure upwards under the panel until it is removed.
      Chiedi a FixBot
      Aggiungi Commento
    2. Beats Studio 2 Wireless Battery Replacement: passo 2, immagine 1 di 2 Beats Studio 2 Wireless Battery Replacement: passo 2, immagine 2 di 2
      • Remove the four screws securing the housing with a Phillips #00 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    3. Beats Studio 2 Wireless Battery Replacement: passo 3, immagine 1 di 1
      • Use a spudger to release the clip in the seam under the silver “studio” label.
      • Remove the right side of the headband.
      Chiedi a FixBot
      Aggiungi Commento
    4. Beats Studio 2 Wireless Battery Replacement: passo 4, immagine 1 di 1
      • Gently remove the right earphone speaker from the headband by sliding the speaker downwards.
      Chiedi a FixBot
      Aggiungi Commento
    5. Beats Studio 2 Wireless Battery Replacement: passo 5, immagine 1 di 3 Beats Studio 2 Wireless Battery Replacement: passo 5, immagine 2 di 3 Beats Studio 2 Wireless Battery Replacement: passo 5, immagine 3 di 3
      • Use the pointed tip of a spudger to carefully push on each side of the connector to release it from the socket on the motherboard.
      • Be gentle with the connectors as they can break easily.
      • Don't use a metal spudger to remove a battery or any internal component. This is potentially dangerous as it could puncture the battery and cause a fire or worse.
      • Use a nylon spudger to remove the battery from the headphones.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 50
Ultimi 30 giorni: 200
Tutti i Tempi: 6,964
