Salta al contenuto principale
BLU Life XL Volume Control Buttons Replacement
Cosa ti serve
  1. BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: passo 1, immagine 1 di 3 BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: passo 1, immagine 2 di 3 BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: passo 1, immagine 3 di 3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
    Chiedi a FixBot
    Aggiungi Commento
  2. BLU Life XL Volume Control Buttons Replacement: passo 2, immagine 1 di 2 BLU Life XL Volume Control Buttons Replacement: passo 2, immagine 2 di 2
    • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  3. BLU Life XL Volume Control Buttons Replacement: passo 3, immagine 1 di 2 BLU Life XL Volume Control Buttons Replacement: passo 3, immagine 2 di 2
    • Firmly press the prying tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
    • Run the prying tool around the entire phone separating the rear plate from the frame.
    Chiedi a FixBot
    Aggiungi Commento
  4. BLU Life XL Volume Control Buttons Replacement: passo 4, immagine 1 di 3 BLU Life XL Volume Control Buttons Replacement: passo 4, immagine 2 di 3 BLU Life XL Volume Control Buttons Replacement: passo 4, immagine 3 di 3
    • Gently remove the tape covering the volume control buttons. The tape is located near the top left of the cavity for the battery.
    • Replace the component and reapply the tape over the buttons.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
USF Tampa, Team S2-G5, Eyestone Spring 2018 Membro di USF Tampa, Team S2-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S2G5
3 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 6
Ultimi 30 giorni: 43
Tutti i Tempi: 637
