Salta al contenuto principale
Atari Flashback 2 Console Power Button Replacement
Cosa ti serve
  1. Atari Flashback 2 Console Power Button Replacement, Console Power Button: passo 1, immagine 1 di 3 Atari Flashback 2 Console Power Button Replacement, Console Power Button: passo 1, immagine 2 di 3 Atari Flashback 2 Console Power Button Replacement, Console Power Button: passo 1, immagine 3 di 3
    • Using the screwdriver and PH1 bit, unscrew the five 10.0 mm screws.
    • One is under the main sticker in the middle of the console.
    Chiedi a FixBot
    Aggiungi Commento
  2. Atari Flashback 2 Console Power Button Replacement: passo 2, immagine 1 di 3 Atari Flashback 2 Console Power Button Replacement: passo 2, immagine 2 di 3 Atari Flashback 2 Console Power Button Replacement: passo 2, immagine 3 di 3
    • Use a PH1 screwdriver to unscrew the two 9.0 mm screws on the circuit board that corresponds to the red power button.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
    • A spring may pop out.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Faith Julian
Membro da: 09/18/18
205 Reputazione
2 guide realizzate
1Commento della guida
Hello. I just bought a used atari flashback 2 and when I turn it on it seems that the power button is a little tricky. I wiggle the button in and out and half way etc. then sometimes I can get it to turn on. Once on, the video 'pulses' on and off and a pulsing sound is noticeable. Is it just a faulty power button or is it something worse like a power regulator. I've taken it apart and all seems to be ok looking ie. no burnt fuses etc.  Can you help?  ~Brad Beachin~
bradbeachin - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 9
Ultimi 30 giorni: 50
Tutti i Tempi: 1,473
