Introduzione
The battery is what gives the headset the power to run and function. This guide will show you how to remove the battery from the headset.
Cosa ti serve
Remove the magnetic ear pads by gently pulling them away from the headset. Be careful not to remove the left earpad, which houses the microphone, and ensure you're only removing the right earpad.
Remove the five 6mm PH1 screws.
Remove the buttons panel by pulling the panel away from the white ribbon cord.
Disconnect the battery wires by desoldering them.
Altre 14 persone hanno completato questa guida.
15Commenti sulla guida
Where do I buy a battery though….
