Salta al contenuto principale
Anki Vector Capacitive Touch Sensor Replacement
Cosa ti serve
  1. Anki Vector  Capacitive Touch Sensor Replacement, Belts: passo 1, immagine 1 di 1
    • Raise Vector's arms above his head.
    Chiedi a FixBot
    Aggiungi Commento
  2. Anki Vector  Capacitive Touch Sensor Replacement: passo 2, immagine 1 di 2 Anki Vector  Capacitive Touch Sensor Replacement: passo 2, immagine 2 di 2
    • Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
    • Repeat on the other side.
    Chiedi a FixBot
    Aggiungi Commento
  3. Anki Vector  Capacitive Touch Sensor Replacement, LCD Facial Display: passo 3, immagine 1 di 3 Anki Vector  Capacitive Touch Sensor Replacement, LCD Facial Display: passo 3, immagine 2 di 3 Anki Vector  Capacitive Touch Sensor Replacement, LCD Facial Display: passo 3, immagine 3 di 3
    • Using the iFixit opening tool, insert the corner under Vector's golden side panel and lightly twist.
    • Repeat this step on the other side.
    • The panel should pop off without much force.
    Chiedi a FixBot
    Aggiungi Commento
  4. Anki Vector  Capacitive Touch Sensor Replacement: passo 4, immagine 1 di 3 Anki Vector  Capacitive Touch Sensor Replacement: passo 4, immagine 2 di 3 Anki Vector  Capacitive Touch Sensor Replacement: passo 4, immagine 3 di 3
    • Insert the corner of the square end of the spudger under the side plate above the partially visible screw.
    • Lightly turn the spudger to separate the plate from Vector's head.
    • Work the spudger around the plate until it comes off.
    • Repeat this step on the the other side.
    Chiedi a FixBot
    Aggiungi Commento
  5. Anki Vector  Capacitive Touch Sensor Replacement: passo 5, immagine 1 di 2 Anki Vector  Capacitive Touch Sensor Replacement: passo 5, immagine 2 di 2
    • Using a Phillips #0 screwdriver, unscrew the two 2 mm screws on the side of Vector's head.
    • Repeat this step on the opposite side.
    Chiedi a FixBot
    Aggiungi Commento
  6. Anki Vector  Capacitive Touch Sensor Replacement: passo 6, immagine 1 di 2 Anki Vector  Capacitive Touch Sensor Replacement: passo 6, immagine 2 di 2
    • Pull apart Vector's head. It should separate down the middle.
    • Remove the screen protector by gently pulling it free from the two face halves.
    Chiedi a FixBot
    Aggiungi Commento
  7. Anki Vector  Capacitive Touch Sensor Replacement: passo 7, immagine 1 di 3 Anki Vector  Capacitive Touch Sensor Replacement: passo 7, immagine 2 di 3 Anki Vector  Capacitive Touch Sensor Replacement: passo 7, immagine 3 di 3
    • Using your thumb and index finger, unplug the display from the plug in Vector's neck.
    • Pull the LCD and speaker assembly from Vector's head.
    • There is a very thin insulating rubber sheet located at the base of the screen. Be careful not to tear it when removing the display.
    Chiedi a FixBot
    Aggiungi Commento
  8. Anki Vector  Capacitive Touch Sensor Replacement, Capacitive Touch Sensor: passo 8, immagine 1 di 2 Anki Vector  Capacitive Touch Sensor Replacement, Capacitive Touch Sensor: passo 8, immagine 2 di 2
    • Using the Jimmy, insert the straight edge of the blade in recess groove in Vector's front wheel.
    • Slowly apply torque to the jimmy until the wheel cover pops off.
    • Repeat for the rear wheel.
    Chiedi a FixBot
    Aggiungi Commento
  9. Anki Vector  Capacitive Touch Sensor Replacement: passo 9, immagine 1 di 2 Anki Vector  Capacitive Touch Sensor Replacement: passo 9, immagine 2 di 2
    • Using a Phillips #0 screwdriver, unscrew the two screws on the exposed wheels.
    • Once the screws are gone, remove the wheels from Vector's body.
    • Repeat this on the other side.
    Chiedi a FixBot
    Aggiungi Commento
  10. Anki Vector  Capacitive Touch Sensor Replacement: passo 10, immagine 1 di 3 Anki Vector  Capacitive Touch Sensor Replacement: passo 10, immagine 2 di 3 Anki Vector  Capacitive Touch Sensor Replacement: passo 10, immagine 3 di 3
    • Gently remove the rear panel by griping it towards the top and pulling out and up.
    • Gently pull out the ribbon cable from the plug between the motherboard and the weight.
    Chiedi a FixBot
    Aggiungi Commento
  11. Anki Vector  Capacitive Touch Sensor Replacement: passo 11, immagine 1 di 3 Anki Vector  Capacitive Touch Sensor Replacement: passo 11, immagine 2 di 3 Anki Vector  Capacitive Touch Sensor Replacement: passo 11, immagine 3 di 3
    • Using a Phillips #0 screwdriver, unscrew the two screws located behind Vector's neck.
    • Lift the capacitive touch sensor assembly off of the body
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Shay Takei
Membro da: 04/16/19
1.795 Reputazione
5 guide realizzate
Cal Poly, Team S2-G6, Maness Spring 2019 Membro di Cal Poly, Team S2-G6, Maness Spring 2019
CPSU-MANESS-S19S2G6
4 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 46
Tutti i Tempi: 1,984
