Salta al contenuto principale
Anker SoundCore 2 Microphone Replacement
Cosa ti serve
    1. Anker SoundCore 2 Microphone Replacement, Front Panel: passo 1, immagine 1 di 2 Anker SoundCore 2 Microphone Replacement, Front Panel: passo 1, immagine 2 di 2
      • Insert a spudger between the front panel and the body of the speaker.
      • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
      Chiedi a FixBot
      Aggiungi Commento
    1. Anker SoundCore 2 Microphone Replacement, Microphone: passo 2, immagine 1 di 3 Anker SoundCore 2 Microphone Replacement, Microphone: passo 2, immagine 2 di 3 Anker SoundCore 2 Microphone Replacement, Microphone: passo 2, immagine 3 di 3
      • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
      • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
      • Flip up the speaker mount panel from the speaker housing case.
      Chiedi a FixBot
      Aggiungi Commento
    2. Anker SoundCore 2 Microphone Replacement: passo 3, immagine 1 di 3 Anker SoundCore 2 Microphone Replacement: passo 3, immagine 2 di 3 Anker SoundCore 2 Microphone Replacement: passo 3, immagine 3 di 3
      • Disconnect the microphone wire from the motherboard.
      • Use a spudger to pry the microphone out of the speaker mount panel.
      • The microphone is held in place with glue, so you may need to re-glue the new microphone onto the speaker mount panel.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 12
Ultimi 30 giorni: 50
Tutti i Tempi: 1,633
