Salta al contenuto principale
Alienware AW610M Side Button Replacement
Cosa ti serve
  1. Alienware AW610M Side Button Replacement, Battery: passo 1, immagine 1 di 3 Alienware AW610M Side Button Replacement, Battery: passo 1, immagine 2 di 3 Alienware AW610M Side Button Replacement, Battery: passo 1, immagine 3 di 3
    • Power off the mouse and disconnect any wired connections.
    Chiedi a FixBot
    Aggiungi Commento
  2. Alienware AW610M Side Button Replacement: passo 2, immagine 1 di 2 Alienware AW610M Side Button Replacement: passo 2, immagine 2 di 2
    • Use a spudger to gently lift and remove the old mouse feet.
    • If the feet are sticky, try lifting slowly from one corner to avoid tearing them.
    • Be careful not to scratch the mouse surface or damage the plastic housing.
    Chiedi a FixBot
    Aggiungi Commento
  3. Alienware AW610M Side Button Replacement: passo 3, immagine 1 di 2 Alienware AW610M Side Button Replacement: passo 3, immagine 2 di 2
    • Remove the four 6.5 mm screws using a Y1 Tri-Point screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  4. Alienware AW610M Side Button Replacement: passo 4, immagine 1 di 2 Alienware AW610M Side Button Replacement: passo 4, immagine 2 di 2
    • Using an opening tool, gently pry apart the two halves of the mouse case. Start at the seam and work your way around until the housing is separated.
    • Don't pull the halves completely apart, as internal wires still connect them.
    Chiedi a FixBot
    Aggiungi Commento
  5. Alienware AW610M Side Button Replacement: passo 5, immagine 1 di 3 Alienware AW610M Side Button Replacement: passo 5, immagine 2 di 3 Alienware AW610M Side Button Replacement: passo 5, immagine 3 di 3
    • Remove the battery pack inside the mouse.
    • If you are having trouble, use a small flat tool to help ease it out.
    • The battery is lightly glued to the mouse, so ease it out gently to avoid breaking the battery or wiring
    Chiedi a FixBot
    Aggiungi Commento
  6. Alienware AW610M Side Button Replacement: passo 6, immagine 1 di 2 Alienware AW610M Side Button Replacement: passo 6, immagine 2 di 2
    • Remove the old battery from its spot. Lift the wire connector away from the mainboard to disconnect it.
    • Make sure all wires are inside the mouse before sealing it shut for easy reassembly.
    Chiedi a FixBot
    Aggiungi Commento
  7. Alienware AW610M Side Button Replacement, Side Button: passo 7, immagine 1 di 2 Alienware AW610M Side Button Replacement, Side Button: passo 7, immagine 2 di 2
    • Remove the single 5.4 mm screw using a Phillips #1 screwdriver.
    • Detach the cable connector, and remove the scroll wheel.
    • Gently detach the last connector using your fingers.
    • Be careful when unplugging all connectors to prevent tearing them.
    Chiedi a FixBot
    Aggiungi Commento
  8. Alienware AW610M Side Button Replacement: passo 8, immagine 1 di 1
    • Turn the large shell casing so that the inside faces you.
    • Using a Phillips #1 screwdriver, remove six 5.4 mm screws.
    Chiedi a FixBot
    Aggiungi Commento
  9. Alienware AW610M Side Button Replacement: passo 9, immagine 1 di 2 Alienware AW610M Side Button Replacement: passo 9, immagine 2 di 2
    • Using your fingers, disconnect the plastic tab in the middle of the large shell casing to access the side buttons.
    Chiedi a FixBot
    Aggiungi Commento
  10. Alienware AW610M Side Button Replacement: passo 10, immagine 1 di 3 Alienware AW610M Side Button Replacement: passo 10, immagine 2 di 3 Alienware AW610M Side Button Replacement: passo 10, immagine 3 di 3
    • Remove the side button on the inner side of the wall using a plastic opening tool.
    • Be gentle prying the side buttons off to avoid breaking them.
    • When reassembling, position the new side button assembly into the slot, aligning it with tabs. Snap it securely into place using a plastic opening tool or your fingers.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Texas Tech, Team 46-4, Johansen Fall 2025 Membro di Texas Tech, Team 46-4, Johansen Fall 2025
TTU-JOHANSEN-F25S46G4
4 Membri
5 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 9
Ultimi 30 giorni: 43
Tutti i Tempi: 227
