Salta al contenuto principale
Acer AL1916 Display Replacement
Cosa ti serve
    1. Acer AL1916 Display Replacement, Stand: passo 1, immagine 1 di 1
      • Lay the monitor on a flat surface so that the back is facing up.
      Chiedi a FixBot
      Aggiungi Commento
    2. Acer AL1916 Display Replacement: passo 2, immagine 1 di 2 Acer AL1916 Display Replacement: passo 2, immagine 2 di 2
      • Grab the hinge cover with both hands on either side of the stand.
      • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
      Chiedi a FixBot
      Aggiungi Commento
    3. Acer AL1916 Display Replacement: passo 3, immagine 1 di 2 Acer AL1916 Display Replacement: passo 3, immagine 2 di 2
      • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
      • Support the monitor while removing the screws to prevent the monitor from falling.
      • Lift up to detach the stand.
      Chiedi a FixBot
      Aggiungi Commento
    1. Acer AL1916 Display Replacement, Outer Case: passo 4, immagine 1 di 2 Acer AL1916 Display Replacement, Outer Case: passo 4, immagine 2 di 2
      • Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
      Chiedi a FixBot
      Aggiungi Commento
    2. Acer AL1916 Display Replacement: passo 5, immagine 1 di 3 Acer AL1916 Display Replacement: passo 5, immagine 2 di 3 Acer AL1916 Display Replacement: passo 5, immagine 3 di 3
      • Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel.
      • Tilt the plastic opening tool up to separate the back cover from the display bezel.
      • Continue around the perimeter of the monitor until the display bezel comes off.
      • A reasonable amount of force is necessary to detach the back cover from the display bezel.
      Chiedi a FixBot
      Aggiungi Commento
    3. Acer AL1916 Display Replacement: passo 6, immagine 1 di 2 Acer AL1916 Display Replacement: passo 6, immagine 2 di 2
      • Reposition the monitor so that the back is facing up.
      • Grab the corners of the monitor and jiggle them upwards to detach the back cover from the inside of the monitor.
      • Lift the back cover up.
      Chiedi a FixBot
      Aggiungi Commento
    1. Acer AL1916 Display Replacement, EMI Shield: passo 7, immagine 1 di 2 Acer AL1916 Display Replacement, EMI Shield: passo 7, immagine 2 di 2
      • Remove the two 5.7 mm Phillips #2 screws located on either side of the EMI shield.
      Chiedi a FixBot
      Aggiungi Commento
    2. Acer AL1916 Display Replacement: passo 8, immagine 1 di 2 Acer AL1916 Display Replacement: passo 8, immagine 2 di 2
      • Using a nut driver (or if necessary, needle-nose pliers), remove the two nuts on either side of the VGA input.
      Chiedi a FixBot
      Aggiungi Commento
    3. Acer AL1916 Display Replacement: passo 9, immagine 1 di 3 Acer AL1916 Display Replacement: passo 9, immagine 2 di 3 Acer AL1916 Display Replacement: passo 9, immagine 3 di 3
      • Grab the metal casing by the sides and slide it down towards the bottom of the monitor.
      • Lift up to remove the metal casing.
      • Beware, metal casing is sharp!
      Chiedi a FixBot
      Aggiungi Commento
    1. Acer AL1916 Display Replacement, Display: passo 10, immagine 1 di 2 Acer AL1916 Display Replacement, Display: passo 10, immagine 2 di 2
      • Remove the three gold 7.5 mm Phillips #2 screws and one silver 8.3 mm Phillips #2 screw from the power supply.
      Chiedi a FixBot
      Aggiungi Commento
    2. Acer AL1916 Display Replacement: passo 11, immagine 1 di 3 Acer AL1916 Display Replacement: passo 11, immagine 2 di 3 Acer AL1916 Display Replacement: passo 11, immagine 3 di 3
      • Remove the two pieces of yellow tape on the left side of the power supply.
      Chiedi a FixBot
      Aggiungi Commento
    3. Acer AL1916 Display Replacement: passo 12, immagine 1 di 2 Acer AL1916 Display Replacement: passo 12, immagine 2 di 2
      • Remove the four little white clips located underneath the pieces of tape by lifting up on their left side.
      Chiedi a FixBot
      Aggiungi Commento
    4. Acer AL1916 Display Replacement: passo 13, immagine 1 di 3 Acer AL1916 Display Replacement: passo 13, immagine 2 di 3 Acer AL1916 Display Replacement: passo 13, immagine 3 di 3
      • With the needle-nose pliers, remove the four display connectors by pulling directly left.
      Chiedi a FixBot
      Aggiungi Commento
    5. Acer AL1916 Display Replacement: passo 14, immagine 1 di 3 Acer AL1916 Display Replacement: passo 14, immagine 2 di 3 Acer AL1916 Display Replacement: passo 14, immagine 3 di 3
      • Remove the display cable located at the top of the circuit board by pulling it out towards the top of the monitor.
      Chiedi a FixBot
      Aggiungi Commento
    6. Acer AL1916 Display Replacement: passo 15, immagine 1 di 3 Acer AL1916 Display Replacement: passo 15, immagine 2 di 3 Acer AL1916 Display Replacement: passo 15, immagine 3 di 3
      • Turn the monitor on its side so that the power supply and circuit board are facing to the right
      • Remove the two 6.6 mm Phillips #2 screws located on both sides of the metal casing (four screws total).
      Chiedi a FixBot
      Aggiungi Commento
    7. Acer AL1916 Display Replacement: passo 16, immagine 1 di 2 Acer AL1916 Display Replacement: passo 16, immagine 2 di 2
      • Set the monitor back down so that the power supply and circuit board are facing you.
      • Feed all four of the connector wires down through the metal casing.
      Chiedi a FixBot
      Aggiungi Commento
    8. Acer AL1916 Display Replacement: passo 17, immagine 1 di 3 Acer AL1916 Display Replacement: passo 17, immagine 2 di 3 Acer AL1916 Display Replacement: passo 17, immagine 3 di 3
      • Grab the sides of the metal casing and lift up.
      • Turn the display over to see the front; you are ready replace the broken display with a new one!
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
Keith
Membro da: 10/06/11
375 Reputazione
4 guide realizzate
Cal Poly, Team 20-26, Maness Fall 2011 Membro di Cal Poly, Team 20-26, Maness Fall 2011
CPSU-MANESS-F11S20G26
4 Membri
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 5
Ultimi 30 giorni: 42
Tutti i Tempi: 9,969
