Salta al contenuto principale
APEX TM785CH Battery Replacement
Cosa ti serve
  1. APEX TM785CH Battery Replacement, Back Casing: passo 1, immagine 1 di 2 APEX TM785CH Battery Replacement, Back Casing: passo 1, immagine 2 di 2
    • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
    • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
    • Move along the top edge of the tablet and repeat the step above.
    • Pull the back cover away from the tablet body to completely remove it.
    Chiedi a FixBot
    Aggiungi Commento
  2. APEX TM785CH Battery Replacement, Battery: passo 2, immagine 1 di 2 APEX TM785CH Battery Replacement, Battery: passo 2, immagine 2 di 2
    • With the back cover removed, you can now see the battery.
    • You will need a soldering/desoldering kit to desolder the 3 battery leads to the circuit board.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Baylor, Team 4-1, Williams Spring 2015 Membro di Baylor, Team 4-1, Williams Spring 2015
BU-WILLIAMS-S15S4G1
3 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 35
Tutti i Tempi: 2,488
