Salta al contenuto principale
4Sight 9 Digitizer Replacement
Cosa ti serve
    1. 4Sight 9 Digitizer Replacement, Cover: passo 1, immagine 1 di 2 4Sight 9 Digitizer Replacement, Cover: passo 1, immagine 2 di 2
      • Place the tablet on its side so that the two screws are facing upward.
      • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. 4Sight 9 Digitizer Replacement: passo 2, immagine 1 di 1
      • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
      • Once loosened, use your hands to separate the case from the device.
      Chiedi a FixBot
      Aggiungi Commento
    3. 4Sight 9 Digitizer Replacement: passo 3, immagine 1 di 2 4Sight 9 Digitizer Replacement: passo 3, immagine 2 di 2
      • Hold the positive and negative wires as close as possible to the speaker.
      • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
      Chiedi a FixBot
      Aggiungi Commento
    1. 4Sight 9 Digitizer Replacement, Motherboard: passo 4, immagine 1 di 1
      • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
      • For a complete guide on how to solder, click here.
      Chiedi a FixBot
      Aggiungi Commento
    2. 4Sight 9 Digitizer Replacement: passo 5, immagine 1 di 2 4Sight 9 Digitizer Replacement: passo 5, immagine 2 di 2
      • Grip the ribbon located at the far end of the circuit board with a plastic spudger tool.
      • Put pressure on the connector until the clasp comes undone.
      • Gently pull up on electrical ribbon until it disconnects from circuit board.
      Chiedi a FixBot
      Aggiungi Commento
    3. 4Sight 9 Digitizer Replacement: passo 6, immagine 1 di 2 4Sight 9 Digitizer Replacement: passo 6, immagine 2 di 2
      • Remove the second electrical ribbon from the motherboard.
      • Use the technique for the previous ribbon.
      Chiedi a FixBot
      Aggiungi Commento
    4. 4Sight 9 Digitizer Replacement: passo 7, immagine 1 di 1
      • Using #00 Phillips Screwdriver, remove the four 1mm screws holding the circuit board to the device.
      Chiedi a FixBot
      Aggiungi Commento
    5. 4Sight 9 Digitizer Replacement: passo 8, immagine 1 di 2 4Sight 9 Digitizer Replacement: passo 8, immagine 2 di 2
      • With fingers, grip the green Wi-Fi connector.
      • Gently pull up on connector to remove tape holding the connector in place.
      Chiedi a FixBot
      Aggiungi Commento
    6. 4Sight 9 Digitizer Replacement: passo 9, immagine 1 di 1
      • Using your fingers, gently lift the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    1. 4Sight 9 Digitizer Replacement, Digitizer: passo 10, immagine 1 di 3 4Sight 9 Digitizer Replacement, Digitizer: passo 10, immagine 2 di 3 4Sight 9 Digitizer Replacement, Digitizer: passo 10, immagine 3 di 3
      • Insert plastic prying tool under screen and exert pressure, pulling upward.
      • Repeat this strep around each corner of screen until it pops off.
      Chiedi a FixBot
      Aggiungi Commento
    2. 4Sight 9 Digitizer Replacement: passo 11, immagine 1 di 1
      • Place heating pad on glass frame in order to loosen adhesive for 3 to 5 minutes.
      Chiedi a FixBot
      Aggiungi Commento
    3. 4Sight 9 Digitizer Replacement: passo 12, immagine 1 di 1
      • Use fingers to gently pull digitizer off of device.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 11
Ultimi 30 giorni: 28
Tutti i Tempi: 1,547
