Salta al contenuto principale
4Sight 9 Battery Replacement
Cosa ti serve
  1. 4Sight 9 Battery Replacement, Cover: passo 1, immagine 1 di 2 4Sight 9 Battery Replacement, Cover: passo 1, immagine 2 di 2
    • Place the tablet on its side so that the two screws are facing upward.
    • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  2. 4Sight 9 Battery Replacement: passo 2, immagine 1 di 1
    • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
    • Once loosened, use your hands to separate the case from the device.
    Chiedi a FixBot
    Aggiungi Commento
  3. 4Sight 9 Battery Replacement: passo 3, immagine 1 di 2 4Sight 9 Battery Replacement: passo 3, immagine 2 di 2
    • Hold the positive and negative wires as close as possible to the speaker.
    • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
    Chiedi a FixBot
    Aggiungi Commento
  4. 4Sight 9 Battery Replacement, Battery: passo 4, immagine 1 di 1
    • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
    • For a complete guide on how to solder, click here.
    Chiedi a FixBot
    Aggiungi Commento
  5. 4Sight 9 Battery Replacement: passo 5, immagine 1 di 2 4Sight 9 Battery Replacement: passo 5, immagine 2 di 2
    • Insert plastic prying tool under upper-hand corner of battery and slide back and forth.
    • Once loosened, insert plastic prying tool under lower-hand corner and repeat sliding action.
    • Repeat previous actions until battery comes loose from device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 8
Ultimi 30 giorni: 45
Tutti i Tempi: 2,209
