Salta al contenuto principale
2,26 o 2,4 GHz / Telaio unibody in plastica bianca
Time to replace the Thermal Paste?
I've had my MacBook 2.26 GHz Core 2 Duo (13-inch Late 2009) MC207LL/A MacBook 6,1 - A1342 for going on three years this December, I bought it used through eBay and it's been running great after numerous upgrades / replaced parts including the Cooling Fan so I know that's not an issue.
I've Googled what the normal operating temperature should be and it seems to be in the normal range but suddenly the range keeps changing from 104° F to 122° F ( CPU die ) with the exhaust fan running at 6200 RPM + - ( smcFanControl ) but not holding steady or dropping below that range. ( Battery power )
Same readings with iStat Menus -
The only app running right now is Safari and CPU usage is not abnormal , Background processes aren't out of bounds.
Sensors check out, Could it be time to replace the Thermal Paste on the heatsink ?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione prescelta
Make sure your fan vents are clean.
Here's how to get to the heat sink: Sostituzione dissipatore di calore MacBook Unibody modello A1342
Here's a guide on replacing thermal paste: Come applicare la Pasta Termica
Here's where to get the thermal paste: [prodotto collegato mancante o disabilitato: IF179-010]
Immagine Electronics Skills
Guida
Difficoltà:
Moderato
5 - 20 minutes
Immagine MacBook Unibody Model A1342 Dissipatore di calore
Guida
Difficoltà:
Difficile
15 - 30 minutes
Punteggio 2
If the cooling fan is running then i would try and replace the thermal past just to see if that fixes the issue it it does not then the issue is something else. It is always best to start cheap then work your way up when fixing issues.
Punteggio 1
Aggiungi la tua risposta
David Bell sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 12
Tutti i Tempi: 3,223
