Wiki con Collaborazione Studenti
Un fantastico team di studenti del nostro programma educativo ha realizzato questo wiki.
Laptop Will Not Turn On
Laptop is unresponsive and shows no sign of powering up.
Faulty Power Chord
Make sure the power chord is properly plugged into the laptop and a functioning power outlet. If the charging light on the power chord does not light up, the power chord needs to be replaced.
Faulty Battery
If the laptop is properly plugged in, the power chord is displaying the power light, and the laptop is still not powering up, the battery is faulty and must be replaced using this guide.
Laptop Has Blank or Black Screen
The monitor on your Toshiba Satellite C875 is not displaying anything on the screen while powered on.
Settings Need Adjustment
First, make sure that the brightness on the laptop is turned up by adjusting the settings on your laptop. To do this, hold down the Fn key on your keyboard while pressing the F7 key until desired brightness is reached. The device may also be in power saving mode causing it to dim the display. Plug in your laptop to ensure it is fully charged and not in power saving mode to avoid a dim screen.
Disabled Display
Make sure the display has not been sent to a second screen or set to projector mode by holding down the Windows key while pressing the “P” key twice. By doing this, you reset the display to “Computer Only” which reverts the display to your laptop screen.
Faulty Screen
If you have completed the steps above and the screen is still not functioning, you may need to replace it using the Display Replacement Guide.
Laptop Shuts Off When Unplugged
While working on the laptop when it is unplugged, the device shuts off without notification.
Laptop is Improperly Updated
Certain old system updates through Windows 10 may cause random shutdowns. In order to avoid this, make sure your laptop is always up to date with the latest software. To do this, press the Windows key and click the gear icon on the bottom left of the start menu to access settings. Next, click the “Update & Security” category and finally click “Check for Updates.”
Battery Requires Replacement
If all software is up to date and the device still shuts off while unplugged, the battery may be reaching the end of its shelf life and will need to be replaced.
Laptop Freezes During Use
Laptop does not respond to any manual prompts; display remains the same.
Laptop Requires Restart
Often times, devices require a restart to run properly if they have not been shut off for a long period of time. Restart your laptop by holding the power button for 10 seconds or until the power light shuts off, then press the power button again to start up the laptop.
Not Enough RAM Storage
The RAM temporarily stores data which is cleared after each restart. In order for the laptop to run efficiently, the RAM cannot be full. RAM becomes full when too many tasks are running on the device. If you are experiencing freezing issues after restarting your device, you may need to upgrade your RAM.
Hard Drive is Faulty
The Hard Drive stores all device data and allows the computer to run smoothly. Once all software and RAM has been checked and you are still experiencing freezing issues, the hard drive may be at fault. If this is the case, the hard drive must be replaced.
Failing Motherboard
If all the above issues have been ruled out, the motherboard may be failing which means it will require a replacement using the Motherboard Replacement Guide.
Laptop Overheats
Toshiba Satellite laptop shuts off without notification while in use.
Dust in Vents
Laptops may overheat if too much dust accumulates in the vents. To remove this dust you can use a compressed air duster to gently blow the dust out of the vents.
Un commento
unable boot from usb
Ergeta - Replica
