Salta al contenuto principale
Toshiba Satellite C875-S7304 Display Replacement
Cosa ti serve
  1. Toshiba Satellite C875-S7304 Display Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite C875-S7304 Display Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite C875-S7304 Display Replacement, Battery: passo 1, immagine 3 di 3
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 Display Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C875-S7304 Display Replacement: passo 2, immagine 2 di 2
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 Display Replacement: passo 3, immagine 1 di 1
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 Display Replacement: passo 4, immagine 1 di 1
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 Display Replacement: passo 5, immagine 1 di 1
    • Lift the battery out carefully using two hands.
  6. Toshiba Satellite C875-S7304 Display Replacement, Display: passo 6, immagine 1 di 2 Toshiba Satellite C875-S7304 Display Replacement, Display: passo 6, immagine 2 di 2
    • Carefully flip the device back over so that the 'TOSHIBA' logo faces away from you.
    • Open the laptop to show the display.
  7. Toshiba Satellite C875-S7304 Display Replacement: passo 7, immagine 1 di 1
    • Use the spudger to remove the screw covers and then remove the screws using the Phillips #1.
  8. Toshiba Satellite C875-S7304 Display Replacement: passo 8, immagine 1 di 2 Toshiba Satellite C875-S7304 Display Replacement: passo 8, immagine 2 di 2
    • Using the iFixit opening tool, carefully remove the plastic frame from the display.
  9. Toshiba Satellite C875-S7304 Display Replacement: passo 9, immagine 1 di 1
    • Remove two screws from each hinge on either side using the Phillips #1 screwdriver.
    • There are two screws on each hinge.
  10. Toshiba Satellite C875-S7304 Display Replacement: passo 10, immagine 1 di 1
    • Rotate the laptop so that the side is facing you.
    • Remove the three screws using the Phillips #1 screwdriver on each side of the display.
    • There will be six total screws removed in this step (three on each side face).
  11. Toshiba Satellite C875-S7304 Display Replacement: passo 11, immagine 1 di 1
    • Turn the display over to expose the wiring on the other side.
  12. Toshiba Satellite C875-S7304 Display Replacement: passo 12, immagine 1 di 2 Toshiba Satellite C875-S7304 Display Replacement: passo 12, immagine 2 di 2
    • Gently loosen the sliding bracket and remove the cable.
    • If you want to use the same webcam, disconnect it from the back of the display.
  13. Toshiba Satellite C875-S7304 Display Replacement: passo 13, immagine 1 di 1
    • With the display now fully disconnected, carefully remove it from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
I love this site....best
Hafiz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 45
Tutti i Tempi: 915
