Salta al contenuto principale
Toshiba Satellite C875-S7304 Battery Replacement
  1. Toshiba Satellite C875-S7304 Battery Replacement, Battery: passo 1, immagine 1 di 3 Toshiba Satellite C875-S7304 Battery Replacement, Battery: passo 1, immagine 2 di 3 Toshiba Satellite C875-S7304 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 Battery Replacement: passo 2, immagine 1 di 2 Toshiba Satellite C875-S7304 Battery Replacement: passo 2, immagine 2 di 2
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 Battery Replacement: passo 3, immagine 1 di 1
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 Battery Replacement: passo 4, immagine 1 di 1
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 Battery Replacement: passo 5, immagine 1 di 1
    • Lift the battery out carefully using two hands.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 27
Tutti i Tempi: 709
