Salta al contenuto principale
« Torna a Tutte le Storie
Resurrecting an Old Workhorse
Becky Hansmeyer -
iPod 4th Generation or Photo
Immagine Storia
  • Immagine n.1
  • Immagine n.2
iPod 4th Generation or Photo Battery Replacement
15 minuti - 1 ora
Moderate
Il Mio Problema
My old iPod 4th Gen/Photo couldn't hold a charge anymore, and it seemed a shame to abandon it when new batteries are so cheap. At 60GB, it can still hold my entire music library.
La Mia Riparazione
It was fairly difficult to pry the iPod apart; I broke one small plastic iPod opening tool in the process and ended up wedging a credit card in the opening to keep it from snapping shut while I worked my way around the side of it. It was also really difficult to get the old battery disconnected...ended up using needle nose pliers to wiggle the connector back and forth. Even with those struggles, the replacement took less than 10 minutes.
Il Mio Consiglio
Discovered that the casing can withstand a fair amount of brute force! Also, you may need to get creative with the tools you use to pry it open and remove the battery.
Immagine iPod 4G/Photo Battery
$13.99
0 Commenti
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 0
Tutti i Tempi: 51
