Salta al contenuto principale
« Torna a Tutte le Storie
Beats Buying New
nickbidinger -
MacBook Pro 15" Unibody Late 2008 and Early 2009
Immagine Storia
MacBook Pro 15" Unibody Late 2008 and Early 2009 Upper Case Replacement
45 minuti - 3 ore
Difficult
Il Mio Problema
Spilt beer on keyboard. After a dry out period I confirmed that the computer still worked, as did the keyboard, but after a brief warm up period the keys would get sticky and the aroma of the the ale became more evident.
La Mia Riparazione
Great walk though. I took it all apart the day before it arrived and put it back together the next day.
Il Mio Consiglio
I used masking tape to hold the screws as I removed them. I labeled them first with the step I was on and the size and amount of the screws(ex: step6 10.5 x3, 3.7 x2). This worked out great. Because of this I realize the numbers in step 8 are flip-flopped. There are two 3.5mm Phillips screws and four 3.2mm Phillips screws.
Also of note: the replacement top case came with a new battery connector installed so step 27 was unnecessary. Also, not mentioned in the guide is the removal of the plastic beam that the optical drive, one of the fans and the logic board all connect to - this was needed as it didn't come with the replacement. Also, I used this opportunity to clean out the fans with a q-tip after removing half the cotton.
Immagine MacBook Pro 15" Unibody (Late 2008-Early 2009) Upper Case
$49.99
0 Commenti
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 7
Tutti i Tempi: 143
