Salta al contenuto principale
« Torna a Tutte le Storie
switch the HDD with a SSD
jmduno -
iMac Intel 27" EMC 2309 and 2374
Immagine Storia
  • Immagine n.1
  • Immagine n.2
Installing iMac Intel 27" EMC 2309 and 2374 Dual Drive
1 - 2 ore
Moderate
Il Mio Problema
To increase performance.
La Mia Riparazione
i had the possibility to fix the ssd with 2 screw on the backside of the Optical Bay, so i did.
I was not able to put back the last screw of step 15 ( Installazione del Secondo Drive SSD nell'iMac Intel EMC 2309 ed EMC 2374 da 27" ) on the optical bay.
A little pain about reconnecting the optical sensor in the good way.
I disassembly the computer up on his feet, but for put back the screen, I had to put the computer down Because, the screw holes was not aligned correctly due to the weight of the screen.
the vertical sync ribbon cable is the main tricky part of the reassembly. It's hard to reconnect it.
Il Mio Consiglio
I loved the Magnetic Project Mat ! So use it !
Immagine iMac & Mac mini Dual Drive Enclosure
$19.99
Immagine Heavy-Duty Suction Cups (Pair)
$16.95
Immagine Magnetic Project Mat
$19.95
Immagine Pro Tech Toolkit
Pro Tech Toolkit
$79.95
0 Commenti
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 9
Tutti i Tempi: 66
