Salta al contenuto principale
« Torna a Tutte le Storie
Nearly perfect home button replacement
platima -
iPhone 4
Immagine Storia
  • Immagine n.1
  • Immagine n.2
iPhone 4 Home Button Replacement
2 ore
Difficult
Il Mio Problema
The previous home button was old, hard to press, and nearly impossible to double-tap. I also though a white button on a black iPhone would look pretty awesome.
La Mia Riparazione
The repair wasn't hard, just took a while. Unfortunately when I put it back together though, the screen was on a slight angle and I have a thin tapered line at the top of the screen as a result (seen in the image).
Il Mio Consiglio
Yeah, video record what you do so you can play it back if you're unsure about clips, screws, etc. Also be careful that you don't move the LCD panel attached to the front glass and end up with the result I did!
0 Commenti
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 1
Ultimi 30 giorni: 4
Tutti i Tempi: 246
