Salta al contenuto principale
« Torna a Tutte le Storie
Power supply replacement
lazzeostergaard -
Immagine Storia
  • Immagine n.1
  • Immagine n.2
  • Immagine n.3
Il Mio Problema
I bought an Imac 24 on the Swedish ebay "Tradera" guessing that there was a problem with the power supply. Thanks to the guide here on ifixit I thought that I give it a try so I ordered a new power supply, 3 screwdrivers and suction cups.
La Mia Riparazione
Thanks to the guide on ifixit i managed to replace the power supply in half an hour. I was very excited when I first pressed the power button and I could here the apply startup sound, however, the power supply was not the only part that was corrupt. The hard drive was also bad so I had to take the Imac apart one more time to replace the hard drive (had one 1 TB laying around).
Il Mio Consiglio
It is a good idea to be 2 persons doing this repair. If one can hold the LCD you don't even need to disconnect the LCD. That will save you some time.
Immagine T6 Torx Screwdriver
T6 Torx Screwdriver
$9.99
Immagine Heavy-Duty Suction Cups (Pair)
$16.95
Immagine TR10 Torx Security Screwdriver
$5.99
0 Commenti
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 17
Tutti i Tempi: 58
