Salta al contenuto principale
« Torna a Tutte le Storie
iMac SSD Upgrade
Carl Hill -
iMac Intel 27" EMC 2639
Immagine Storia
  • Immagine n.1
  • Immagine n.2
  • Immagine n.3
iMac Intel 27" EMC 2639 Hard Drive Replacement
2 ore
Moderate
Il Mio Problema
The oem 2TB HDD was just full and unable to boot. Opted to upgrade to SSD and reinstall OS.
La Mia Riparazione
Everything well very well. The kit was well worth the money as I likely would have failed without it. The new adhesive is easy to work with, the foam brace makes things easy and the SSD Temp sensor likely would have been forgotten if I hadn't just purchased this kit.
Il Mio Consiglio
Removing the screen can be tricky but just keep cutting and prying gently and slowly and it will come out. Removing and routing the cables around the HDD can be tricky but again just don't force anything and be patient.
Immagine iMac Intel 27" (Late 2012-2019) SSD Upgrade Kit
$115.99
0 Commenti
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 8
Tutti i Tempi: 271
