Salta al contenuto principale
« Torna a Tutte le Storie
2011 iPhone 4s First-Time Battery Replacement
Leandro de la Rosa -
iPhone 4S
Immagine Storia
iPhone 4S Battery Replacement
3 ore
Moderate
Il Mio Problema
The battery's lifespan has severely degraded after 7 years. The indicator gets stuck on 1% for a long time.
La Mia Riparazione
It went well with the exception of the removal of the 1.7 mm Phillips screw by the battery connector. The reason it took my battery replacement process 3 hours is that I stripped the aforementioned screw. The included iFixit screwdriver's Phillips screw attachment for reason didn't go well with the 1.7 mm screw. After I miraculously removed the stripped screw, everything else went without a hitch.
Il Mio Consiglio
Don't strip any screws. If you think you are careful during the unscrewing process, you should probably be a little bit more careful.
Immagine iPhone 4S Battery
iPhone 4S Battery
$18.99
0 Commenti
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 8
Tutti i Tempi: 246
