Salta al contenuto principale
« Torna a Tutte le Storie
Easy battery replacement
William Neuson -
MacBook Pro 15" Unibody Early 2011
Immagine Storia
MacBook Pro 15" Unibody Early 2011 Battery Replacement
20 minuti
Moderate
Il Mio Problema
My MacBook battery began to fail and expanded to the point of temporarily deforming the aluminum near the trackpad.
La Mia Riparazione
Using the iFixit Pro Tech Toolkit, I followed the instructions in the step-by-step guide. The battery charged in a few hours and proceeded to work fine.
Il Mio Consiglio
In the event that the battery swells, remove the screws from the case closest to the failing section of the battery. Use a flat tool to carefully help the battery case out of the machine if the swelling is enough to deform the case.
Immagine MacBook Pro 15" Unibody (Early 2011-Mid 2012) Battery
$69.99
0 Commenti
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 9
Tutti i Tempi: 123
