Salta al contenuto principale
« Torna a Tutte le Storie
Replaced iPad Air Front Panel
maliawaddell -
iPad Air Wi-Fi
Immagine Storia
  • Immagine n.1
  • Immagine n.2
  • Immagine n.3
iPad Air Wi-Fi Front Panel Assembly Replacement
2 ore
Difficult
Il Mio Problema
My iPad had the ghost touching problem, where it just started freaking out and opening apps without being touched. My research pointed to a digitizer problem. I also had a small cracked screen area.
La Mia Riparazione
I had mixed results. Eventually I fixed it. Getting the original screen off with all that adhesive was no joke. I also cracked my replacement screen trying to install the home button and had to order another. The home button still doesn't respond as well as the original. But I have a functioning iPad again! So I'll consider it a win.
Il Mio Consiglio
Definitely order the replacement assy that has the adhesive and home button pre-installed. A razor blade and a blow dryer were my main tools used to remove the screen.
Immagine iPad Air Screen Digitizer
$29.99
1 Commento
Sounds tricky, but glad you worked it out!
Cynthia Replogle - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 5
Tutti i Tempi: 166
