Salta al contenuto principale
« Torna a Tutte le Storie
MacBook SSD Upgrade
Eric Outen -
MacBook Core Duo
Immagine Storia
MacBook Core Duo Hard Drive Replacement
10 minuti
Easy
Il Mio Problema
This wasn't necessarily a fix, but I wanted to speed up my 2007 MacBook because it still works great for Photoshop and Illustrator. I was also holding off upgrading the OS to Lion until I could get an SSD so the installation process would be less tedious. I purchased a Crucial 240GB SSD from Amazon which is double the storage of the 120GB SATA that came with the MacBook.
La Mia Riparazione
The hard drive swap couldn't have been any easier. I might have hit a snag if I didn't already have a screw driver set with Torx screw bits, but the screws stick out far enough that someone could unscrew them with a small pair of pliers I suppose. I don't think it took longer than ten minutes to swap the hard drives and get everything back together.
Il Mio Consiglio
I would highly recommend reading through the guide carefully and making sure you have a set of Torx screwdrivers available. Otherwise, if you're comfortable with removing the battery and undoing a couple screws I don't think you should run into any problems.
Immagine TR8 Torx Security Screwdriver
$5.99
0 Commenti
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 10
Tutti i Tempi: 775
