Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
MacBook Air 11" (Late 2010) Replacement Battery
  • MacBook Air 11" (Late 2010) Replacement Battery / Fix Kit
  • MacBook Air 11" (Late 2010) Replacement Battery / Part Only / New
  • 360°
360
84,99 USD
84,99 USD
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Kit cacciaviti Manta
112 punte per ogni riparazione.
Upgrade Your Toolbox
Dettagli Prodotto
Descrizione
Descrizione
This MacBook Air 11" (Late 2010) replacement battery is what you need to bring your dead MacBook Air 11" (Late 2010) to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 4550 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your MacBook Air's lifespan, extend it with this new replacement battery compatible with MacBook Air 11" (Late 2010). Factory-installed MacBook Air 11" (Late 2010) batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Contenuto del kit
Contenuto del kit
Compatibilità
Compatibilità
  • MacBook Air 11" A1370 Late 2010 1.4 GHz or 1.6 GHz
Specifiche
Specifiche
Model #:
A1375
Watt Hours:
35 Wh
Voltage:
7.3 V
Milliamp Hours:
4790 mAh
Manufacturer:
Aftermarket
Compatibilità
MacBook Air 11" Late 2010
A1370 (EMC 2393) 1.4 GHz
A1370 (EMC 2393) 1.6 GHz
Recensioni dei clienti
