Salta al contenuto principale
MacBook Air 11" Late 2010 Battery Replacement
Cosa ti serve
  1. MacBook Air 11" Late 2010 Battery Replacement, Lower Case: passo 1, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, close your computer and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
    Chiedi a FixBot
  2. MacBook Air 11" Late 2010 Battery Replacement: passo 2, immagine 1 di 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    Chiedi a FixBot
  3. MacBook Air 11" Late 2010 Battery Replacement, Battery: passo 3, immagine 1 di 2 MacBook Air 11" Late 2010 Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
    Chiedi a FixBot
  4. MacBook Air 11" Late 2010 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
    Chiedi a FixBot
  5. MacBook Air 11" Late 2010 Battery Replacement: passo 5, immagine 1 di 1
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
    Chiedi a FixBot
Conclusione
Altre 119 persone hanno completato questa guida.
21Commenti sulla guida
This looks like an excellent how-to! Especially liked the location illustration of different length battery screws.
My only comment would be to have a tray ready to put the screws in - looks like they could easily be lost.
Leonard - Rispondi Condividi
Now my touchpad isn't working as well as before. Any ideas why?
todd rumaner - Rispondi Condividi
Dead on Accurate. Was very easy. I would change the rating from moderate to easy. The hardest part is getting the correct screw drivers.
Phil Blake - Rispondi Condividi
hello, is there any difference between A1370 (late 2010) battery part and a A1370 (2011) battery?
Carlo Mejia - Rispondi Condividi
I'm also wondering the same thing. Did you find the answer to your question? Thank you.
swj.sean - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 34
Ultimi 30 giorni: 244
Tutti i Tempi: 112,538
