Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Logitech Lift, usa il nostro manuale di assistenza.
    1. Logitech Lift Teardown, The Exterior: passo 1, immagine 1 di 3 Logitech Lift Teardown, The Exterior: passo 1, immagine 2 di 3 Logitech Lift Teardown, The Exterior: passo 1, immagine 3 di 3
      • Exterior shots of the mouse. Flip over to begin.
      Chiedi a FixBot
      Aggiungi Commento
    2. Logitech Lift Teardown, Taking Out Battery and Receiver: passo 2, immagine 1 di 3 Logitech Lift Teardown, Taking Out Battery and Receiver: passo 2, immagine 2 di 3 Logitech Lift Teardown, Taking Out Battery and Receiver: passo 2, immagine 3 di 3
      • Remove the battery cover, battery, and USB receiver.
      Chiedi a FixBot
      Aggiungi Commento
    3. Logitech Lift Teardown, Accessing Base Screws: passo 3, immagine 1 di 3 Logitech Lift Teardown, Accessing Base Screws: passo 3, immagine 2 di 3 Logitech Lift Teardown, Accessing Base Screws: passo 3, immagine 3 di 3
      • There are screws hidden beneath the PTFE skates. Carefully lift one end with a pointed tool and remove completely.
      • Avoid bending or stretching the skates excessively, they are easy to crease. Try to maintain a 30 degree angle and pry gently for best results.
      Chiedi a FixBot
      Aggiungi Commento
    4. Logitech Lift Teardown, Separating the Base: passo 4, immagine 1 di 3 Logitech Lift Teardown, Separating the Base: passo 4, immagine 2 di 3 Logitech Lift Teardown, Separating the Base: passo 4, immagine 3 di 3
      • Use rubbing alcohol to clean the leftover adhesive, 91% isopropyl alcohol works well and does not damage the plastic. The PTFE skates will stick better during reassembly by doing this.
      • Remove the six screws highlighted in the photo. They are identical so mixing them is fine.
      • Gently pull the base apart from the top shell to expose a gap. The slot where the battery inserts into is a solid place to grip.
      • The base an the top shell are connected with a delicate ribbon cable. Do not use excessive force or it may be damaged.
      Chiedi a FixBot
      Aggiungi Commento
    5. Logitech Lift Teardown, Separating the Base: passo 5, immagine 1 di 3 Logitech Lift Teardown, Separating the Base: passo 5, immagine 2 di 3 Logitech Lift Teardown, Separating the Base: passo 5, immagine 3 di 3
      • Use a guitar pick or similar plastic tool to further split the base from the top shell.
      • There is a clip that holds the two pieces together, highlighted in the second photo. Running the guitar pick across that area should pop it open.
      • The base and top shell should separate with minimal force after the clip is undone.
      Chiedi a FixBot
      Aggiungi Commento
    6. Logitech Lift Teardown, Detaching Ribbon Cable from Sensor Board: passo 6, immagine 1 di 3 Logitech Lift Teardown, Detaching Ribbon Cable from Sensor Board: passo 6, immagine 2 di 3 Logitech Lift Teardown, Detaching Ribbon Cable from Sensor Board: passo 6, immagine 3 di 3
      • On the circuit board of the base, there is a connector holding the ribbon cable in place. Gently flip the black piece up with a fingernail and the cable can be removed with minimal force.
      Chiedi a FixBot
      Aggiungi Commento
    7. Logitech Lift Teardown, Removing Sensor Board: passo 7, immagine 1 di 3 Logitech Lift Teardown, Removing Sensor Board: passo 7, immagine 2 di 3 Logitech Lift Teardown, Removing Sensor Board: passo 7, immagine 3 di 3
      • The sensor board is connected to the base with 3 identical screws. Remove them and the board can be lifted out easily by the battery contacts.
      • The power switch slider is loose and should drop out after the circuit board is removed. It can only be reassembled in one direction, so there's no need to keep track of the orientation.
      Chiedi a FixBot
      Aggiungi Commento
    8. Logitech Lift Teardown, Close-Ups of Sensor Board: passo 8, immagine 1 di 2 Logitech Lift Teardown, Close-Ups of Sensor Board: passo 8, immagine 2 di 2
      • Detailed view of the sensor board.
      Chiedi a FixBot
      Aggiungi Commento
    9. Logitech Lift Teardown, Separating the Grip: passo 9, immagine 1 di 3 Logitech Lift Teardown, Separating the Grip: passo 9, immagine 2 di 3 Logitech Lift Teardown, Separating the Grip: passo 9, immagine 3 di 3
      • Remove all 11 screws that are visible in the top shell. They are identical so just keep them together in a safe place.
      • Gently pry at the rubber grip using a plastic tool like a spudger. This piece is held in strongly by a few plastic clips.
      Chiedi a FixBot
      Aggiungi Commento
    10. Logitech Lift Teardown, Separating the Grip: passo 10, immagine 1 di 3 Logitech Lift Teardown, Separating the Grip: passo 10, immagine 2 di 3 Logitech Lift Teardown, Separating the Grip: passo 10, immagine 3 di 3
      • Continue prying around the grip, then pull the pieces apart.
      • This is the most challenging part of the disassembly because it takes quite a bit of force, is hard to grip, and it is difficult to tell if something will break. Do not give up, it gets easier from here.
      Chiedi a FixBot
      Aggiungi Commento
    11. Logitech Lift Teardown, Close-Ups of Gripless Lift: passo 11, immagine 1 di 2 Logitech Lift Teardown, Close-Ups of Gripless Lift: passo 11, immagine 2 di 2
      • Detailed view of the top shell without a grip.
      Chiedi a FixBot
      Aggiungi Commento
    12. Logitech Lift Teardown, Removing Right Button: passo 12, immagine 1 di 3 Logitech Lift Teardown, Removing Right Button: passo 12, immagine 2 di 3 Logitech Lift Teardown, Removing Right Button: passo 12, immagine 3 di 3
      • The right button is attached with two screws, as highlighted. These are different from screws from previous steps, so keep them separate.
      • Gently lift the connecting piece with a tool, then continue lifting it while also pushing it forward, as seen in the third photo.
      Chiedi a FixBot
      Aggiungi Commento
    13. Logitech Lift Teardown, Removing Left Button: passo 13, immagine 1 di 3 Logitech Lift Teardown, Removing Left Button: passo 13, immagine 2 di 3 Logitech Lift Teardown, Removing Left Button: passo 13, immagine 3 di 3
      • The button is held in place by a beam and its corresponding slot, which is why it cannot be lifted straight up.
      • Take out the 2 screws for the left button and remove it in the same way as the right button. The screws for these two buttons are the same.
      • Putting the buttons back on is fairly straightforward. Just press down while pulling it backwards, the opposite motion of taking them off, and they should snap into place. Make sure to put the right button on first.
      Chiedi a FixBot
      Aggiungi Commento
    14. Logitech Lift Teardown, Removing DPI Button: passo 14, immagine 1 di 3 Logitech Lift Teardown, Removing DPI Button: passo 14, immagine 2 di 3 Logitech Lift Teardown, Removing DPI Button: passo 14, immagine 3 di 3
      • Take out the screw holding the DPI button in place. It should come out easily with a bit of prying.
      • This screw is unique, do not mix it with any other screw.
      Chiedi a FixBot
      Aggiungi Commento
    15. Logitech Lift Teardown, Removing Switch Assembly: passo 15, immagine 1 di 3 Logitech Lift Teardown, Removing Switch Assembly: passo 15, immagine 2 di 3 Logitech Lift Teardown, Removing Switch Assembly: passo 15, immagine 3 di 3
      • The switch assembly is snapped into place. Pry at the locations indicated in the first and second photo and it can be removed from the top shell with minimal force.
      Chiedi a FixBot
      Aggiungi Commento
    16. Logitech Lift Teardown, Removing Side Buttons: passo 16, immagine 1 di 3 Logitech Lift Teardown, Removing Side Buttons: passo 16, immagine 2 di 3 Logitech Lift Teardown, Removing Side Buttons: passo 16, immagine 3 di 3
      • The side buttons are also held in with a snap fit. Pry at the locations indicated to loosen them. The buttons themselves might get caught on the casing, so push them in to remove them.
      • It is recommended to skip this step unless the buttons are being replaced, it does not get in the way of any other disassembly.
      Chiedi a FixBot
      Aggiungi Commento
    17. Logitech Lift Teardown, Removing Switch Button Frame: passo 17, immagine 1 di 2 Logitech Lift Teardown, Removing Switch Button Frame: passo 17, immagine 2 di 2
      • The switch button frame is held in place with 3 screws. Remove them and it will lift right out.
      Chiedi a FixBot
      Aggiungi Commento
    18. Logitech Lift Teardown, Removing Scroll Wheel: passo 18, immagine 1 di 2 Logitech Lift Teardown, Removing Scroll Wheel: passo 18, immagine 2 di 2
      • The scroll wheel is held in place with 2 screws.
      • A commenter mentioned that the mouse will not power up and connect to a computer without the scroll wheel in place.
      Chiedi a FixBot
      Aggiungi Commento
    19. Logitech Lift Teardown, Separating Switch Board from Frame: passo 19, immagine 1 di 3 Logitech Lift Teardown, Separating Switch Board from Frame: passo 19, immagine 2 di 3 Logitech Lift Teardown, Separating Switch Board from Frame: passo 19, immagine 3 di 3
      • The side buttons are mounted to the frame with 2 screws. Once they are removed, the boards can be gently pried away from the frame.
      • It is okay to bend the ribbon cable so that the boards are easier to remove. Try not to flex it more than necessary to prevent damage.
      Chiedi a FixBot
      Aggiungi Commento
    20. Logitech Lift Teardown, Detaching Ribbon Cable from Switch Board: passo 20, immagine 1 di 2 Logitech Lift Teardown, Detaching Ribbon Cable from Switch Board: passo 20, immagine 2 di 2
      • The ribbon cable can be released from the switch board by pulling on the two white tabs on the connector. The ribbon cable should come out very easily, do not force it.
      • Take note of the orientation of the ribbon cable, or it will not reassemble in the same way.
      Chiedi a FixBot
      Aggiungi Commento
    21. Logitech Lift Teardown, Close-Ups of Switch Board and Switch Dimensions: passo 21, immagine 1 di 3 Logitech Lift Teardown, Close-Ups of Switch Board and Switch Dimensions: passo 21, immagine 2 di 3 Logitech Lift Teardown, Close-Ups of Switch Board and Switch Dimensions: passo 21, immagine 3 di 3
      • Detailed view of the switch boards and switch dimensions.
      • The primary buttons are 6.2mm × 6.2mm, 7.3mm tall (circuit board to top of button), and have a pin pitch of 5mm.
      • The middle click and DPI button have the same dimensions, but are 5mm tall instead.
      Chiedi a FixBot
      Aggiungi Commento
    22. Logitech Lift Teardown, Switch Dimensions: passo 22, immagine 1 di 3 Logitech Lift Teardown, Switch Dimensions: passo 22, immagine 2 di 3 Logitech Lift Teardown, Switch Dimensions: passo 22, immagine 3 di 3
      • When purchasing new switches, they may be labeled as 6mm instead (6*6*7.3mm, for example). This is fine, the schematic in the product listing should show the correct dimensions.
      • There are red versions of these switches that seem to be identical and can be found on AliExpress, made by the same company "Kailh". The switches purchased for this mouse were titled "1/3/5Pcs Kailh Mute Button 6*6*7.3mm Square Silent Wireless Wired Mouse Micro switch Mouse Button Tact Switch" and sold by Kailh's official store.
      Chiedi a FixBot
      Aggiungi Commento
    23. Logitech Lift Teardown, Disassembly Complete!: passo 23, immagine 1 di 1
      • Congrats! If you are reading this then either one of your primary buttons is probably double clicking. Best of luck with the repair!
      Chiedi a FixBot
      Aggiungi Commento
James Huang
Membro da: 12/06/24
767 Reputazione
2 guide realizzate
7Commenti sulla guida
Thank You!!!
Zegarmistrz Swiatla - Rispondi Condividi
Thank you for this tear down. I was looking for ways to save this mouse I gave as a present as it was really ergonomic to use.
Whatever switches Logitech were soldering onto these are extremely unreliable.
Arvin Alvarez (Calvira) - Rispondi Condividi
Thank you for the teardown! The left mouse switch on my Logitech Lift went bad - clicks didn't consistently register and it sometimes let go while dragging. This guide was super useful in helping me replace it - for reference, I used a Kailh Mute Red switch (6x6x7.3mm).
One thing I noticed is that the mouse doesn't power on and connect if the scroll wheel is missing. If you're trying to test the mouse before fully reassembling, it's worth putting the switch assembly back together first (as pictured in step 18) so that the scroll wheel is in position.
Ace4896 - Rispondi Condividi
You're welcome! And thanks for the heads up, I'll add a note to step 18.
James Huang - Rispondi Condividi
Thank you @jameshuang7!!! I was able to (terribly, miraculously) solder in some new switches after my left-click stopped consistently registering clicks. @ace4896 was correct about needing the scroll wheel in place for the mouse to boot up. How bizarre. Perhaps some sort of self test procedure.
Jacob Hanson (jeb) - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 28
Ultimi 7 giorni: 210
Ultimi 30 giorni: 858
Tutti i Tempi: 11,280
