Salta al contenuto principale
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
ipad 2 disabled connect to itunes
Tried DFU mode and tried to restore on 3 different computers running windows XP Pro & windows 7 Home Premium and itunes. ipad 2 not recognized, I have a second ipad 2 works fine on all the above.
any suggestions.
Thanks
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Have you tried bypassing the "ipad is disabled" screen? There is an easy way to do it with the first ipad and I have heard that it now works with the ipad 2 by selecting ipad from the drop down menu in Gecko. The instructions can be found here.
Punteggio 4
1 Commento:
I try to click the found here link and it tells me forbidden cannot connect to this
What do I do I have one I pad stuck in activation mode and one that just says connect to iTunes but when I do it doesn't read that its connected or when it does says restore failed why
da
Aggiungi la tua risposta
Larry sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 10,443
