Salta al contenuto principale
L'Acer One 10 S1003-114M è un dispositivo convertibile, che può funzionare sia come tablet che come computer portatile.
Display doesn't power on
On my Acer One 10 S1003-114M I have installed incorrect graphics drivers then the device when off, since then has never powered on again, but when I plug a charger cable I can see the charging light, please help on how to fix this issue. Thank you in advance.
Questa è una buona domanda?
Punteggio 0
1 Commento
no it's not the problem actually the main problem is it is not being power on even I ma clicking the power button
da Condividi
Aggiungi un commento
1 Risposta
Soluzione prescelta
Your Acer One 10 likely entered a deep power-state glitch or suspended state (a "soft brick") due to the incorrect graphics driver. You can fix this by performing an internal battery reset to clear the system's memory and force a proper boot. Post your question in your browser and the AI will give you the details.
Punteggio 1
1 Commento:
Thanks a lot I will do it you mentioned.
da Condividi
Aggiungi la tua risposta
ZANDILE GRACE sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 47
Tutti i Tempi: 188
