Salta al contenuto principale
Repair and disassembly guides for Brother printers.
Brother MFC-8460N Printer Error
My brother printer always displays this error when i power it on..it lights a red blight then displays this error message..Machine Error. Contact Technical Support
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@onneilecas43557 following the MACHINE ERROR you should see another error code appear on the LCD. If not then check to see if this will tell you how to possibly finding the real error code. Just check 8.4.16
Now, if all you are getting is the The "Machine Error. Contact Technical Support" message then this is very generic for a mechanical failure. Could be the fuser or even the scanner malfunction. You would have to work through the troubleshooting section of the Brother Fax MFC 8460 Parts & SM for your printer.
Punteggio 1
Aggiungi la tua risposta
Onneile Casius william sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 18
