Salta al contenuto principale
La Canon PIXMA G3010 è una stampante MegaTank wireless tutto-in-uno, lanciata all'inizio del 2018. Supporta la stampa, la scansione e la copia, con Wi-Fi integrato e connessione Wireless Direct per una facile stampa da dispositivi mobili
Printer won't feed paper
Even it have a stack of papers, it doesn't eat them it just stay there on
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
@gumbanyvan45991 if you have the same issue when the tray is low on paper, the problem is likely in the feed roller assembly. This usually points to worn-out pick-up rollers. It could also be a sensor detecting a jam or foreign objects stuck in the paper path. Check the troubleshooting section of the service manual. The disassembly of your printer is shown starting on page 17 of the service manual that you can now download from this page Canon G3010 Printer under the Documents tab.
Of course, you can also check this video for a more visual help with that
Punteggio 0
Aggiungi la tua risposta
Gumban, Yvanne Rey A. sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 22
Tutti i Tempi: 219
