Salta al contenuto principale
Il visore per realtà mista Meta Quest 3S è stato rilasciato il 15 ottobre 2024 ed è un fratello minore arrivato dopo il Meta Quest 3.
Headset's tracking completely stopped working
I was playing VRChat on this headset and the tracking on it completely stops working where the cameras are off and the microphone only works if I hold the power button (after 5 seconds of holding it would shut it down) as well as the controllers not responding to anything beside the quest menu button so I had to use the head direction movements and volume buttons to navigate around the menus. I went to the Headset Tracking option and the switch is stuck on as it won't let me toggle it at all.I'vr also used ADB to clear the data of all the oculus system apps and restart it to safe mode but it didn't fix the problem. Is there something wrong with the hardware or does it need to be factory reset?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
I would try to factory reset it but if that doesn't work try to send it back if you have warrenty
Punteggio 0
Aggiungi la tua risposta
Kai Bannon sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 21
Ultimi 30 giorni: 96
Tutti i Tempi: 539
