Salta al contenuto principale
Lanciato a giugno 2012 / processore Core i7 con Turbo Boost / Fino a 1 GB di RAM Video DDR5
597 Domande Visualizza tutte
Swapping harddrive for SSD in MacBook Pro 15 inch (2012).
Hey,
I am looking to swap the harddrive of a new 2012 MacBook pro 15 inch with an SSD and then replace the optical bay with the original
I was wondering if the process is exactly the same as previous models. I have looked at the tear down but wanted to make sure
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Here's an article by OWC and bench results on the 15" standard: http://blog.macsales.com/14263-owc-ssds-...
Punteggio 2
I did this yesterday. I installed a Samsung 512GB SSD. The guide for the late 2011 model did match perfectly:
Sostituzione hard drive MacBook Pro 15" Unibody versione fine 2011
And use this one for cloning the harddisk:
Come installare MacOS High Sierra
Immagine Mac OS X
Guida
Difficoltà:
Facile
1 - 3 hours
Immagine MacBook Pro 15" Unibody Late 2011 Hard drive
Guida
Difficoltà:
Moderato
25 - 40 minutes
Punteggio 0
hi,
I am planning to replace my existing HD with a new SSD. Im on OS X Lion 10.7.4
I need to clone my HD on to my SSD. Can I not do this using my latest Time Machine Back up?
wouldnt the TM back up install the OS plus all my applications and files etc ( basically bring it back to the current state including preferences)?
Is this what time machine is for?
thanks
Punteggio 0
1 Commento:
Akshay,
If you opt to install by using a TM backup, all your data, applications and preferences. The only thing to account for is that the SSD needs to have the more space that what your TM backup uses.
da
Aggiungi la tua risposta
jchu1990 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 12
Tutti i Tempi: 38,389
