Salta al contenuto principale
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Domande Visualizza tutte
Domanda Chiusa
Does not power up
Hello,
I have an iMAC 17", 2 GHz, and by accident my printer's USB cable touched the firewire "400," resulting in my iMAC shutting down and it will not power up when the power switch button is pressed. Any suggestions, advice, or recommendations? Thanking all of you in advance.
HarryJ
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Unplug the machine. Press and hold the power on button for 5 seconds. Plug the machine back in and let us know your results when trying to power on. This failing, remove the frame so you can observe the diagnostic LEDs and try to start up and see what the LEDs show you.
Punteggio 3
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 535
