Salta al contenuto principale
Budget 15" laptop series released by HP.
Why my screen doesn't want to switch on?
The screen doesn't work but the side light show that there's power on the pc. It seems like it doesn't start processing operations on the pc , surprisingly the side power light is on ....
HP 15s-fq3003ni model
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@shalommoloto connect an external monitor and see if that shows properly. If it does then you will know that the issues is with your display. Could be LCD, the display cable or even the display connector.
If the external monitor does not display an image either, then the issue is most likely with your motherboard. Possibly a GPU or other component error. To try an help you with that we would need to see your board and know the exact number for you motherboard. It will be printed on your motherboard. Let us know what you find out. To work on your computer use the HP 15 Maintenance And Service Guide
Aggiungere immagini ad una domanda
Punteggio 0
Aggiungi la tua risposta
Shalom Moloto sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 27
