Salta al contenuto principale
Questo Power Mac G4 è dotato di Mirrored Drive Doors.
Can't install any programs
Hello I have a Power Mac g4 with 500 MHz CPU, 2 GB of Ram, one Maxtor 120 GB and the original 80 GB HDD. My problem is all .dmg image i download when finish and the system mount a error appear (corrupted or damage image) I google all king of solution but I can't fix it the Os i have are Panther and Tiger. I try with Lion, Cheetah, Lion and other X Os but i have the same error. Please help..
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
Sounds like you may have a corrupted system. Your machine will take up to system 10.5.8. Boot from the system installation disk, go to the second screen pull down menu to Disk Utilities. Select your boot drive in the left hand column and see if you can repair the disk. Next repair the permissions. That failing, copy your documents to the other hard drive then reformat the hard drive using the "write zeros" option and reinstall your system.
Punteggio 3
1 Commento:
oK i gonna do that and let you know...
da Condividi
Aggiungi la tua risposta
Rongie sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 19
Tutti i Tempi: 935
