Salta al contenuto principale
Processore dual core Intel Core i5 da 2,3 o 2,6 GHz o quad core Intel Core i7 da 2,7 GHz (fino a 3,7 GHz con Turbo Boost) con 6 MB di cache L3.
Desoldering RAM in order to upgrade possible?
Since the MBA, Apple introduced the soldered RAM. I remember someone who tried desoldering it, so he could upgrade it. Now, in the New MBP with Retina display, they did the same. I regret choosing for the 8GB model, because I want to run some Virtual Machines. Is it possible to desolder it, and upgrade the RAM yourself? (even solder the ram again if needed) Can you guys at iFixit maybe try it out?
Thanks in advance!
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
See if you can return the machine, there's usually a buyers remorse law that says you can for three days and get what you need.
Punteggio 4
1 Commento:
And if you're citizen of the European Union you even get full 14 days.
da
senthor << Only if you bought it online (that is, via a remote shopping facility).
vincent << Often, the store won't turn you down as they prefer a happy customer and an upsale to en unhappy customer and no upsale :)
Punteggio 0
Aggiungi la tua risposta
vincent bosch sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,800
