Hi @dadakota
Here's a tech sheet that is applicable to your washer model.
Check if the Diagnostic LED on the control board is On or Off - see p.2
If it is On, follow the procedure to activate the Service Diagnostic Test mode. - see p.2
If it is Off, perform TEST #1: Main Control, - see p.12.
If you can't active the diagnostic tests go to Unsuccessful Entry - see p.3
If you find the problem and it's due to a faulty part that needs replacing, here's the parts list that is useful.
Locate the wanted part in the list and note the part number that is shown for it. Search online for the part number only to find suppliers that suit you best.
If you search on YouTube for (insert wanted part number) replacement, sometimes if you're lucky you'll find videos showing how to remove/replace the part in the machine.
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
1 Commento
Please edit your question or add a comment listing the model number of your washer. Sears doesn't make any of their appliances and they sell hundreds of different models and manufacturers under the 110 Series label. The only way we can tell anything about yours is with the model number, so it's essential we know that in order to help.
da Jerry Wheeler
