Salta al contenuto principale
Guide e informazioni per la riparazione dei controller Joy-Con di Nintendo Switch.
Why do my Joy-Cons disconnect when they are attached?
My Joy-Cons always seem to disconnect after a period of time. This happens when they are attached to the screen; they seem to disconnect in the middle of games and act as if they came off. It tells me to take both off since I have one attached and one detached, even though they are both attached.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi!
So which side remains "attached" and which side is actually having issues?
Did you tried another Joy-Con, just to be sure?
Otherwise it's the rail that is failing and need to be replaced. Cleaning first is recommended, otherwise you need to replace it.
Example: Nintendo Switch Right Joy Con Sensor Rail Replacement - iFixit Repair Guide
Punteggio 1
Aggiungi la tua risposta
seifhenawy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 14
