Salta al contenuto principale
Informazioni sulla riparazione, lo smontaggio e la risoluzione problemi per l'HMD Fusion, dagli sviluppatori dei telefoni Nokia. Il Fusion è stato lanciato a settembre 2024 e presenta una serie di accessori intelligenti che consentono la personalizzazione.
Where to find an HMD fusion replacement screen?
The HMD fusion TA-1658 replacement screen is out of stock on this website. I am trying to find a reliable replacement elsewhere but not having much luck. Received a kit from Amazon only to find out it didn't include the T3 Torx screwdriver required to remove the screws on the back even though the posting stated it was a kit for a TA-1658. So I decided no to trust them to provide the correct screen replacement and returned it. This is the one I already tried: https://www.amazon.com/HMD-Fusion-Replac...
Thank you for your advice. I really want to at least try to fix it myself but I want to ensure I have the correct parts. Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @nectarine
Search online for 70101506H001 to find suppliers that suit you best.
This is the part number for a HMD Fusion complete display assembly. (examples only)
Punteggio 1
Aggiungi la tua risposta
Nectarine sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 27
Tutti i Tempi: 27
