Salta al contenuto principale
Rilasciata nel novembre 2020, la consolle PS5 si caratterizza per la capacità grafica notevolmente migliorata e un innovativo controller DualSense. Lo schema cromatico futuristico in bianco e nero segna una grande svolta rispetto al design delle PlayStation del passato.
Non Functioning USB's
Hello,
I got in a PS5 with EDM-010 motherboard.
The USB's are in pristine condition but, not a single one connects to the motherboard when console posts to White Light.
That's right the console will turn on and post to White Light. This is supposed to be where you connect a Controller and press the PS5 button to connect controller and start the system to next point.
When I did turn the console on it kept saying and posting that to many USB devices are connected.
Anybody have an idea?
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi!
Hopefully this answer can help you too: My front USB port not reading any of my DualSense
Did you tried with a USB-C to USB-A cable? Or a USB-C to USB-C cable? I would try both, just to test.
Otherwise, replacing the USB ports would be the first test. It could be the USB controller, but this requires soldering…
Please let us know how it goes!
Punteggio 1
2 Commenti:
Koppie007
Yes I’ve tried different combinations of cables and also different dual sense controllers.
The cables and controllers work on other PS5 consoles.
Still stumped.
da
Hmm.. yes, you also tried the USB ports on the back, right? If the same issue occurs there, I think it’s the USB controller that need to be replaced :(… you can try using a different USB board and see how that works out! But I think this is not it..
da
Aggiungi la tua risposta
Marty Robinson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 41
