The screen stopped displaying an image
I already replaced the screen once and it stopped displaying an image, although this is the second screen. It's been 3 months since I replaced it and it's not displaying an image anymore after I opened it to fix the screw. I don't know if I damaged the flat cable.
Questa è una buona domanda?
I have the same problem, the screws from the hinges broke with plastic I opened the laptop to fix it but I don't get an image anymore, the laptop works with an external monitor, I also have sound but not an image, probably the cable from the screen I don't know if you have any idea, I kept inserting the cable from the screen but nothing. PLEASE HELP ME!
da ionut Cristyan
the screen cable (s) run thru the hinges. If they are not loose in the connector (s) it is a good chance they are damaged in the hinge since that is where your problem started.
da bill
Now I noticed that I have the image, it's just very dark, it's probably from the backlight but I don't understand how this happened, I opened the laptop many times for maintenance and there were no problems. Probably a Fuse or something burned on the motherboard
da ionut Cristyan
@ionutcristyan a dark image is likely caused by a backlight problem. The backlight makes the image bright. The backlight might be powered separately via a different cable. so the problem still could be a cable issue. Otherwise, it is a screen issue. On some screens you can replace the backlight or the backlight power4 supply. You just have to figure out what the problem is.
da bill
I have 2 cables that goes from mptherboard to screen first its the flatcable and then the wifi cables.
da ionut Cristyan
Mostra 1 altro commento
