Salta al contenuto principale
Dai un'occhiata a queste guide per trovare informazioni sulla riparazione e sullo smontaggio della tua macchina da cucire.
Consew 230 assembly, troubleshooting, changing oil?
I just got a Consew 230 sewing machine secondhand, and I am having trouble finding any info online about how to set it up (and it's the kind of machine that's built into a wooden tabletop, so I can't exactly bring it to a local shop). I had to disassemble it just to get it home, separating the machine, motor, tabletop, and legs; this model evidently is self-lubricating and has a built-in oil pan, which completely spilled during dissassembly. So, my main questions are:
  1. What kind of oil do I need to refill the oil pan?
  2. How much oil should I put into the pan, and how do I know if everything is connected correctly?
  3. Is there any other good resource for troubleshooting or assembly? The only stuff I've found online are user manuals that explain how to change a bobbin. Nothing mentioning the industrial motor or oil pan mounted to the underside of the table...
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi @etl14855
Here's the parts list diagram for the various 230 series models that may help.
The parts pertaining to the oil pan as shown as parts A9, A10 through to A13. They're a bit hard to locate but hopefully they may give some ideas as how it all fits together.
Unfortunately it doesn't specify the type and amount of oil to use You could always try contacting the manufacturer by email or phone - see image below, and ask them.
(click on image)
Punteggio 0
Aggiungi la tua risposta
e-t-l sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 40
