Salta al contenuto principale
Rilasciato il 01 novembre 2021 204g, 8,3 mm di spessore Android 11, MIUI 12.5 Archiviazione 128GB/256GB, microSDXC
Why It doesn't charge
The phone doesn't charge at all when plugged to the charger
Questa è una buona domanda?
Punteggio 3
1 Commento
Hey there Cecilio, we will need some more details to better help you. Have you tried using a different charger, or tried a different outlet? What troubleshooting steps have you taken so far?
da
Aggiungi un commento
1 Risposta
Risposta più utile
@cecilioperez first check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not, it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit.
Of course, the charging port is soldered to the charging board (sub board) I would replace that board since it commonly is the issue. Since iFixit does not yet have a specific guide for this, use the one from here It is written in Spanish so use a browser that does the translating for you, if needed.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Punteggio 1
Aggiungi la tua risposta
Cecilio Perez sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 27
Tutti i Tempi: 512
