Looking for whirlpool GD5RHAXNQ00 compressor grommets
I'm looking for the correct compressor mounting grommets for Whirlpool GD5RHAXNQ00 at a reasonable price, or at least some grommets that would be comparable. I don't need the bolts, just the grommets. The current grommets are worn out and give way too much play leading to the compressor knocking.
On a side note, the thread hole for the front-right mount will no longer secure the bolt (I tried one of the other bolts and same thing, so it's the hole). I've never used a tap and dye kit to rethread a hole and I only have 9 inches of vertical clearance there to get in and work. Does anyone have an suggestions on a kit that I might be able to use in this situation?
Thanks for your help!
Questa è una buona domanda?
